Help GS3 System update?
ive got the galaxy s3 now and was searching for a system update for it...
can't seem to find anywhere in the phone to do so, i presume there has been system updates for it by now...
where can i find it?
im in the UK on T-mobile if that makes a difference...
Cheers,
Larsson!
Cheers,
Larsson!
Have you tried settings> about Device>Software update? If it says no update found you have the latest update installed on you're device already.
Hope this helps.
Hope this helps.
Yes, that was the first thing i did when booting the phone up from new... there is no button for system/software updates within the about device section (as my HTC had before)...
You can try installing the Kies software from Samsung's website. Kies will tell you if there are any updates for your phone. If you bought the phone brand new it should have the latest and greatest software already.
