I have hboot 1.53 S-ON what I can do? I flashed the roms whit 3ext smart flash but it's not working,its possible to install other rom whitout downgrading hboot?
generally speaking,the AOSP roms(not based on stock sense) use the older 1.49 hboot. becasue there were some changes in the file system,the older hboot does not know how to boot roms designed on the newer filesystem,and vice versa. at least not without changing the rom around to accomodate it.
since the jellybean roms are for the most part AOSP based,you may be having trouble booting them with the newer hboot.
this is all speaking generally,as some devs may be basing their roms now on the newest hboots,but im a bit out of touch with available roms,so im not sure.
as i said prior,you can read the original posts of the roms development thread,and try and find a jb rom that will work with your hboot. aside from that,youll need to be s off so you can downgrade to the older hboot when needed.
also make sure that when you are flashing,that you wipe:
-data/factory reset
-cache
-dalvik cache
and it may be worth trying to install the boot image manually,as maybe smart flash is not working quite correctly.
