markwarder
Hi There.
I have a nice shiny new Samsung - y android phnoe, and this app was the first one I downloaded for it.
Unfortunately it does not give correct readings when running on my phone.
For example:
I have just used an online tuner guitar to play A, the app says its d# 151.3 hz and flat.
I get similar results with instruments which have been tuned with my conventional tuner.
When the app is started it says that the sampling rate is lower than expected and will reset to a lower level. Can this issue be fixed?
Is there a compatibility issue with my phone or am I doing something wrong?
Regards
M.
For example:
Regards
M.
