Help GT-P5110: Firmware Encountered an Issue
Deanface
Hi Guys,
Apologies if there is a duplicate thread, but none of the existing threads helped me for what i have. I have a Samsung Galaxy Tab 2.0 (GT-P5110) and a week or so ago it stopped working. It would first get stuck in the Samsung logo and nothing would happen. So i did some research and found that i can use Odin to do a stock firmware upgrade. I held the power + volume up button to put the device into download mode and did according to the guide and also downloaded the correct stock firmware 4.2.2 for GT-P5110 from sammobile and after it was upgraded and Odin said pass. The tablet then displayed the orange triangle with the message firmware upgrade encountered an issue.
I have tried using Kies, but that does not find the device. I have also tried using the firmware & initialize in kies, but it would say your device does not support initializing. I have done the stock firmware upgrade on Odin again and again, tried Android 4.2.2, 4.1.1 and 4.04 all for GT-P5110 and nothing works. All it says is it has passed and then when i run the device it would say firmware issue encountered. The other thing is, i can no longer start the device in recovery/download mode when pressing the power + volume up and i cannot even turn the device off as it will just go back to the firmware upgrade issue until battery goes flat.
Any advise?
Kind Regards,
Dean.
Hi Guys,
Any advise?
Kind Regards,
Dean.
Hi Dean
I have the same problem exactly like you. Did you find a solution? I appreciate if send reply to my email: amirowji@gmail.com
Regards
