UncreativeUsername
ok so I noticed my status never goes idle when logged on through my phone (I checked this on my desktop through another account.) I let my phone sit there for a hour or so (haha no, I did not sit at the stare at the status for a whole hour if that's what you think) while doing other things on my desktop. when I went to go check my status it still said I was available (I hadn't texted, called, etc.)?
also I know there is a setting to set the status away when the screen turns off. I've checked marked that at one point to test it out, but that didn't work either. is there something I'm doing wrong?
the good news is at least when i set it to away or change the msg that goes with the status, it corresponds. I'm just confused with the other parts I mentioned above.
