Caro332
Android Expert
I have noticed that quite a few people enjoy using Cyanogen and since I did not find any recent guide on flashing the ROM on AF, I thought I would give a simple guide.
Cyanogen 9 from modpunk is available for both Marvel & MarvelC.
This version of CM9 was created by modpunk. I do not take credit for any of this guide or for the rom. I am only creating a simple guide for you guys. If you want more details, please visit modpunk's thread:
[ROM] CyanogenMod 9.0.0-RC2 marvel/marvelc ALPHA7 [UPDATE: 2012-07-27] - xda-developers
Please proceed at your own risk. I do not take any responsability for what you do to your phone. If you brick your phone or encounter any problem, it is not my problem. But I would be happy to try and help out
Requirements:
1)Rooted phone
2)CM9 zip file Ensure you have downloaded the right rom version for your phone i.e. Mavel, MarvelC
3)Gapps zip file
PS: All files are available at the links mentioned at the bottom of the post
Flashing Cyanogen 9
Updating to Cyanogen 9
Enjoy your new ROM!!!
CM9 rom: https://code.google.com/p/cm9-wildfire-s/downloads/list
Gapps: Goo.im Downloads - Browsing gapps
Bugs I noticed so far:
1) HD videos don't work and some animations that are integrated in some apps don't work either (example: BeWeather, Daily ab workout, daily butt workout {yeah I do like to keep in shape
2) Turning the bluetooth on with the Power control doesn't work but if you use the button in the notification drawer or if you manually swtich it on in the options it works
3) Maildroid doesn't work. Keeps on Force closing
4) GPS doesn't work but Google map somehow seems to be working
5) Bar code may not look like it works but it actually does. Just be a but patient and it should be able to read it. I've used it a couple of times already
Requirements:
1)Rooted phone
3)Gapps zip file
Flashing Cyanogen 9
- Install both files on the root of your SD card
- Boot into recovery
- Wipe all data (Factory Reset)
- Wipe Cache
- Wipe Dalvik cache
- flash rom
- flash gapps
- reboot
- Install the rom file on the root of your SD card
- Wipe Dalvik cache
- flash rom
- reboot
If you are using Link2SD
If you use Link2SD, please use the following steps:
Using Link2SD, you need to clear all caches from the app. Then reboot into recovery, install the ROM, install Gapps, then boot. Open Link2SD and menu > more > recreate mount scripts. Reboot.
When it boots, you might get a lot/a few force closes, why? Because the apps cannot find their .dex elements and therefore don't respond on boot. You need to go back into Link2SD, wait a minute, and press menu > more > link dalvik-cache files. Should take a while. When it's done, wait a minute. Reboot. (will take a long time as the .dex files link up again)
Do the same again, open Link2SD, menu > more > link dalvik-cache files. Reboot.
Keep doing this until all of them are linked, or until it says 0.00B linked. Then press menu > more > Relink all Application files, then press Clean up the Second Partition. Then Reboot.
})2) Turning the bluetooth on with the Power control doesn't work but if you use the button in the notification drawer or if you manually swtich it on in the options it works
