thanks jason80 but i think the project froyo folder has everything needed, it's just a matter of figuring out how to utilize the folders and programs. i tried doing the steps with the files i THOUGHT was the right ones but i don't think it went right. when i ran the KP500 utility i got like 3-4 "file error file not found" and when got to the end of process the utility window had a bunch of ??????? and entry window but no text displayed what was going on. i closed the program and i kept getting media, phone and other errors forced closing and rebooting non stop. i then followed tommyh instructions as he had the same issue it seems.
STEP 9a: Once the phone is on, you will probably get a bunch of Force Close boxes. Unplug the phone, and pull the battery then re-insert.-did nothing and rebooted the same thing over and over
STEP 9b: Do a factory reset by pressing and holding VOL UP+HOME+END
I found this at the LGNPST post and it's obviously what I was missing. this seemed to work and my phone rebooted with 2.1 but no root.
i then used the app universal androot to gain root and that worked.
and thats were im at but hardly feel comfortable.
the project froyo folder also has some folders i'm not sure what to do with. sdcard folder. seems im suppose to put these on my sd card but no instructions in the guide or in the file, there's tons of sub folders. workdir folder that contains fastboot and adb utilities and amonra and stock recoverydisc images, again no instructions or idea what to do with these. lastly in the lgvs740 folder is VS740ZV6_01 but it's zipped. this seems to be the back to stock version i was supose to go back to, it asks were to unzip it too. i haven't done anything with the mentioned folders/utilities it just seems i should be doing something with them...
basically i'm completely lost now lmao.
at this point i'm all ears. what i would LIKE to do is make sure i have a stock recovery and confident how to use it, make sure my phone is rooted correctly, and install a custom rom. i've tried going to IRC but im not sure where to go to get help. someone told me #android but when i tried to go there i get - you need to be identified with services.
