Root [GUIDE-How To] odex a deoxed rom[odex apk tool]
Jaay Dogg
Android Expert
Example here I'm using Thing ROM, butyou can use this guide in anyrom 2.3.5 or 2.3.3 and 3.5deodexed
1.Extract ThingROM.zip delete allcontents of /data/app/ only files notfolder 2.Delete following files in /system/app/ folder Gmail.apk Herring.apk Maps.apk Slate.apk Superuser.apk Vending.apk Youtube.apk 3.Re zipAll extracted files name itanything you want copyto sdcard 4.Go torecovery wipe all then install the rom you have made 5.Once finished go to advanced> rebootrecovery[note dont reboot system after flashing onlyrebootrecovery] 6.Once recovery hasstarted Go to mountsand mount system/ mount data/7.Connect usb to phone then run odex script from the file I gave you, but you must extractitfirstofcourse. 8.Once finished. open a new cmd window and type this: note you must have adb installed or open acmd in your adb folder. Make 2foldersin c: named appand framework commands: adb pull/system/app/ C:\app then when finished nextcommand adb pull/system/framework/ c:\framework now when finished copy c: appand framework folder to desktop extractoriginal rom cut2 folders appand framework then move somewhere then copy the app and framework folders from c: to the extractedrom. 9.copyback deletedfiles in 1. and 2. instructions. 10.re zip all files and name the rom toodexThingrom.zip or anything. 11.Now you can flash it. Then you will have 115MB free space odex rom
NOTE: Sometimes system partition becomesfull andrefuses to bootROM cause no space to extractsome files, if this happen trymoving some apps in system/appto data/app like maps.apk/gmail.apk/facebook.apk/ etc.
Download Links com.modaco.odexme.apk
This is not My work just passing it along
