tangodown09
I was super tired and groggy when I made this so it's sloppy but hopefully it will help you. If you have any questions just ask.
I was wondering if it is possible or advisable to root, then uninstall tetris, uno, aim, allshare, messaging, bejeweled, files, and photobucket, glympse. Then to create a nand backup and unroot my phone. The only reason I wanted to root it in the first place was to get rid of some of the useless things taking up space.
I was also wondering if anyone had luck with removing google cloud was that able to be uninstalled without too much fuss and group messaging? The list was posted are those the actual names of the files that I will see with titanium backup pro.
Any thoughts would be exceedingly helpful.
Thanks so much for this thread, it was very helpful. I was removed most of the apps that tangodown09 mentioned in his post. There are a few others I wanted to get rid of, but was wondering if anyone had any experience yes or no on them...
Cloud Texting?
Email? (I only use the Gmail app)
Glympse?
Group Texting?
Latitude? (I do use Maps, but do I need this?)
TelenavGPS?
Visual Voicemail? (I use Google Voice)
So yeah, just curious if anyone has deleted any of these and had any repercussions or not. Thanks SO much for this helpful thread, it was very easy to follow.
Hi, I was able to delete unwanted apps from the system folder with Super Manager. However it would seem the apps are not physically deleted from the phone
