PandaHacker
Member
Rooting this phone isnt something hard. I didn't make the zip file All credit goes to Vadim for actually doing that. I took the update.zip file from the root method of the Huawei Ascend II and flashed it onto my Activa using adb.
The obligatory "I am not responsible to what happens with your phone and you flash this image at your own risk etc etc.. You all basically know the drill ;P"
Before starting make sure that you have the Android sdk installed on your computer. (I recommend installing it to the root directory of your hard drive)
Also install the USB Drivers by auto running the program when you plug in your phone via usb.
Make sure your phone has USB Debugging enabled
And now the process:
1.Download the update.zip via download link below.
2.Copy the download to the root of your phones SD Card
3.Hop on over to command prompt and go into the platform-tools directory of the SDK 'cd \whatever.path.to.sdk\Android\platform-tools'
4.Run 'adb devices' and make sure your device is there, it should say M920
5. If its there then reboot with recovery. 'adb reboot recovery'
6. Once booted into recovery then use the volume up and down buttons to scroll up and down and to select press camera button and then press power button. (Not at the same time
7. Choose update from SD Card.
8. Choose the update.zip from the root of your drive.
9. After its done then reboot your phone and its rooted
Link for Update.zip : Dev-Host - update.zip - The Ultimate Free File Hosting / File Sharing Service
)7. Choose update from SD Card.
