Root [guide]How to superCID
scotty85
Extreme Android User
please note:
*you DO need to be s-off for this to work. you cannot change the CID of an s-on device to superCID without a special,signed by htc file on the sd card
if you dont have adb set up,download this:
mini-adb.zip
it contains adb,fastboot and an md5sums utility
-extract it,place the unzipped folder on the root of your C drive
-open a cmd window(win 7,clock start button,type "command" or "cmd" in search box)
-change to mini-adb directory by typing,or copy/paste in the cmd window:
cd c:\mini-adb you should see your promt change to c:\mini-adb>
-place phone in charge only mode,plug in(im assuming you have rooted via revolutinary and have drivers.if not use revolutioary drivers)
-in cmd,type or copy/paste the bold faced code:
adb devices
-if you get your serial number back,boot to bootloader:
adb reboot bootloader
-check for connectivity
fastboot devices
-if you get a serial number back,check your cid first,in case you want to restore it later
fastboot getvar cid
or
fastboot getvar all (will return other variables as well :))
-change CID
fastboot oem writecid 11111111 (eight ones)
-reboot bootloader
fastboot reboot-bootloader
-check CID again
fastboot getvar cid
or
fastboot getvar all
-verify CID=11111111
-reboot
fastboot reboot
heres what the above will look like in your cmd window(red are my inputs):
Code:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation.  All rights reserved.
C:\Users\Scott>[COLOR="Red"]cd c:\mini-adb[/COLOR]
c:\mini-adb>[COLOR="red"]adb devices[/COLOR]
* daemon not running. starting it now on port 5037 *
* daemon started successfully *
List of devices attached
HTxxxxxxxxxx    device
c:\mini-adb>[COLOR="red"]adb reboot bootloader[/COLOR]
c:\mini-adb>[COLOR="red"]fastboot devices[/COLOR]
HTxxxxxxxxxx    fastboot
c:\mini-adb>[COLOR="red"]fastboot getvar all[/COLOR]
INFOversion: 0.5
INFOversion-bootloader: 1.27.1100
INFOversion-baseband: N/A
INFOversion-cpld: None
INFOversion-microp: None
INFOversion-main: 3.32.531.14
INFOserialno: HTxxxxxxxxxx
INFOimei: xxxxxxxxxxxxxxx
INFOproduct: vigor
INFOplatform: HBOOT-8260
INFOmodelid: PH9810000
INFOcidnum: T-MOB010  [COLOR="Blue"]<-this is your stock cid. make note of it[/COLOR]
INFObattery-status: good
INFObattery-voltage: 3950mV
INFOpartition-layout: Generic
INFOsecurity: off
INFObuild-mode: SHIP
INFOboot-mode: FASTBOOT
INFOcommitno-bootloader: ad3368f2
INFOhbootpreupdate: 11
INFOgencheckpt: 0
all: Done!
finished. total time: 0.529s
c:\mini-adb>[COLOR="red"]fastboot oem writecid 11111111[/COLOR]
                              ... INFOStart Verify: 0
OKAY [  0.261s]
finished. total time: 0.262s
c:\mini-adb>[COLOR="red"]fastboot reboot-bootloader[/COLOR]
     rebooting into bootloader... OKAY [  0.187s]
finished. total time: 0.187s
c:\mini-adb>[COLOR="red"]fastboot getvar cid[/COLOR]
cid: 11111111
finished. total time: 0.003s
c:\mini-adb>[COLOR="red"]fastboot reboot[/COLOR]
                     rebooting...
finished. total time: 0.156s
c:\mini-adb>
_________________________________________________________________
*you can restore your original CID with the same process. do so prior to turning s-on
sensation
hboot1.27.0000
s on
hi mate im rooted and have been trying to super cid my sensation using your method but after i use the command fastboot oem writecid 11111111 i get the following error on the terminal:
C:\adb>fastboot oem writecid 11111111
... INFOvreg_set: request is duplicated id 14
INFO pyramid_init_sd, SD card power on ok
INFOsdcc_init_memory_device done
INFO[FAT_ERROR] fat_open_file: can not find SMART_IO.CRD
INFO[JAVACARD_ERR] SMART_IO.CRD cann't find
OKAY [ 1.120s]
finished. total time: 1.120s
any advice mate?? cheers
sensation
hboot1.27.0000
s on
OKAY [ 1.120s]
ahh,my apologies,this will not work with s-on. it is linked from the other post after the s-off,procedure,but i forgot to include above that s-off is a requirement.
if you want to stay s-on,youre stuck with using ruus and fimrware files that match your CID,or possibly using a gold card.
sorry for the confusion
I typed in fastboot oem writecid 11111111
and i was met with this error:
C:\Users\Francis.BORG-PC\tools>fastboot oem writecid 11111111
(bootloader) [ERR] Command error !!!
OKAY [ 0.016s]
finished. total time: 0.016s
Any ideas?
Make sure you are s off,and make sure you have the phone in fastboot,and not in hboot or the booted OS.
Also make sure you are in the directory containing the fastboot utility
Hi Scotty85 can you make smart_io.crd for HTC Desire C (A320e) PL0110000 cid HTC_038 from original build_Prop. please help
