BlazingFire258
*READ THIS*
First off, when I say "Upgrade" I don't mean it literally but it'll make the Activa feel likes its had an upgrade
THIS GUIDE WILL INCLUDES:
(BLOATWARE)_- - - - - - - - - - - - - - Bloatware that can safely be removed.
(SYSTEM_APPS) - - - - - - - - - - - - - System Apps that can be removed safely.
(THEMES)- - - - - - - - - - - - - - - - - Theming (I'm up for suggestions)
(INTERNAL_STORAGE_SAVER)- - -- - - -Internal Storage Saver (I'll explain down the line)
**PLEASE PRESS THE THANKS AND LIKE BUTTON, ITS ALL I ASK IN RETURN**
!!!!!ROOT IS REQUIRED FOR EVERYTHING!!!!!
_________BLOATWARE_________________________________________________________________
I used Titanium Backup to remove these apps, if you can find another app that does the same hing than go for it.
Bloatware Removal List (All tested personally):
AppStore
MetroPCS Easy Wifi
MetroWEB
MyMetro (IMPORTANT: This will cause infinite force close, wait until you see in
the notification bar that it uninstalled. Onces it does just reboot your phone)
These can be uninstalled normally:
MyExtras
Answers
IM and Social
M Studio
Mail@Metro
Metro 411
Movies
Pocket Express
Rhapsody
Sportacular
_________SYSTEM_APP________________________________________________________________
I use Titanium Backup as well to remove this list.
Clock
Downloads
Email
Gallery
Gmail
Home Screen Tips (Honestly, who ever uses it?)
Kungu Fu Panda (Only if you've deleted the movie from you're sdcard)
Launcher(ONLY UNINSTALL IF YOU ALREADY HAVE ANOTHER LAUNCHER INSTALLED)
Music
Pico TTS
Security
Sound Recorder
Swype
Talk
TTS Service
Voice Dialer
Voice Search
Wiper App
Chinese Keyboard (It's not really called that, the name is in chinese so I can't write it out)
There is a folder in "system/" directory (aka the folder called "system") called "delapp". You can delete the whole folder, its a bloatware folder (literally).
_________THEMES___________________________________________________________________
*I'm working on exact replica of an ICS theme. I'll continue the rest of the guide another day. If you have questions or want to add on please comment*
_________INTERNAL_STORAGE_SAVER____________________________________________________
I will be using the app called APP2ROM. I haven't seen another app that can do the same function.
YOU MUST INSTALL: BusyBox Installer, it can be found on the Play Store
When it's finished installing, launch it, grant it root permission, and install Busy Box 1.9.3 (This phone does not support a later version of BusyBox that I'm aware of) in the location "system/xbin".
You have to scroll down to find the install button ftr.
App2rom will NOT work if you don't do the above.
An explanation of how this will save you internal space on your phone:
There are three types of data storage on an the Huawei Activa; ROM, Internal, and External (aka an SD card). The ROM is a part of the internal storage that users can't change or modify without root access (thats why root permission is necessary). On the ROM are apps such as Play Store, Camera, Music, Dialer, etc that come preinstalled. When you update Play Store (well more like forced to update since it does it without your consent) the newer version is on your internal storage (the part that you're able to use) and the version in your ROM is left untouched. What the app does is that it moves and replaces the version on the ROM with the updated one thus saving you internal storage.
ALL apps can be moved to the ROM to save some space on you're internal storage BUT not all apps work when you move them to the ROM.
Apps that work in ROM:
Clock JB
Google PLay Services
Holo Launcher
Hotmail
NotifierPro
Screenshot ER
Power Toggle
WidgetLocker
SuperSU
Chomp SMS
MIUI Music
Zplayer
Apps that don't work
Quick Pic
*Any types of Keyboard (unless you want to prove me wrong
AppStore
MetroPCS Easy Wifi
MetroWEB
MyExtras
Answers
IM and Social
M Studio
Mail@Metro
Metro 411
Movies
Pocket Express
Rhapsody
Sportacular
Clock
Downloads
Gallery
Gmail
Music
Pico TTS
Security
Sound Recorder
Swype
Talk
TTS Service
Voice Dialer
Voice Search
Wiper App
Clock JB
Holo Launcher
Hotmail
NotifierPro
Screenshot ER
Power Toggle
WidgetLocker
SuperSU
Chomp SMS
MIUI Music
Zplayer
Quick Pic
