FluffyFox
Ok , many of you have been asking why your recoveries aren't showing after you flash a ROM. Well here's how to fix it.
1. (Starting from stock) Download 2nd-init recovery (This will be the only time you use this)
2. Flash your favorite ROM.
3. Once that is done, uninstall 2nd-Init recovery
Note: DO NOT USE 2ND - INIT RECOVERY IN A CUSTOM ROM. MOST ROMS COME WITH A RECOVERY. IF YOU USE 2ND - INIT, YOU WILL HAVE TO UNBRICK AND RE FLASH YOUR ROM TO BE ABLE TO USE THE ROMS RECOVERY
IF YOU USE THE BUILT IN RECOVERY AND YOU GET MORNING CALL ERROR, THEN YOU USED 2nd init.
4. go download Titanium Backup from the Play Store.
5. In Titanium Backup Go to menu (3 lines) > Clean up Dalvik cache.
Then Hold Power > Reboot > Recovery
And it should work fine :3. Just hit the Volume up to refresh the lg start up :3
