Root [Guide] Over-Heating Fix [Working]
FluffyFox
Note: IM NOT RESPONSIBLE FOR ANY DAMAGE DONE TO YOUR DEVICE WHILE DOING THESE TWEAKS/MODS
THANKS GO TO: SwoRNLeaDejZ For the GPS tip. Thank you buddy :3
This is for PlayfulGods Cyanogenmod 10.1
Many of you have seen my post about my Over Heating issue. Well, i have found multiple solutions to this problem.
Solution One: GPS Disable
This one is straight forward. What it does is disable the GPS so it no longer runs.
1. download the fix from here: http://www.mediafire.com/?948g08o9oc7qq2x
2. (Safety Measure) Since this is a flashable file, you may want to back up your Rom and Apps.
3. Reboot into CWM and flash the GPS Fix file.
4. Done
Now I did this, and my phone went to 78-84 degrees. Which is a drastic change.
Shown Here: http://postimg.org/image/w1oeo20oz/
Solution 2: Disabling LTE
Well, my phone has been on EV for a while, and I have grown to like the speed I am getting. So while I was exploring I found and LTE button, so I disabled it to help with less heat.
1. Go to Settings > System > Notification Drawer > Widget Buttons and Check Toggle LTE
2. Go into the notification panel and turn off LTE. (Shown in the same picture above)
Solution 3: Selective Data
Ok , this one is simple.
If your not using any internet at all, just turn it off until you need it again. This will lower your temperature down a little bit.
NOTE: EACH TIME YOU TURN DATA ON, IT WILL HEAT VERY QUICKLY. DONT PANIC. IT WILL COOL DOWN AFTER A BIT.
Solution 4: Processor Clocking
Another simple solution is to use the right Processor Clock setting.
1. Go to Settings > Performance > Processor > CPU Governor > MSM-DCVS
2. Check Set On boot so every time you reboot, it will set the setting back to MSM-DCVS
Solution 5: ZdBox
You can use zdbox to regulate the temperature and use it to kill apps that was a lot of memory.
Well, I hope these helped you guys out like it did me :3 Any questions just post below. :)
