Austrie
Android Expert
PRL = "Peferred Roaming List" is a list that list all the towers the device can connect to. The PRL affects your call quality, data speeds, and signal strength. The newest PRL is not always the best, so play around with each one.
Credit: Ramjet73
Original Thread: http://forum.xda-developers.com/showthread.php?t=2126477
This is a faster method of updating your PRL, compared to the standard method ex. Leslie Ann's "Fix Everything" Method. You will be restoring a backup of a Gingerbread ROM made by ramjet, that has the capabilities to update PRL manually unlike other ROMs, the reason for that is because this ROM has a EPST.APK capable of manually updating PRL. If you're reading this from your phone, its advised to write down the steps before hand being that this ROM do not have any data connection for our phone. The PRL I switched to is 61092, but I plan on trying the older PRLs too. The PRL 61009 is the best PRL at the moment though. Ill be continuing to add PRLs in the future.
Requirements:
S-Off
4Ext(or CWM)
ENG HBoot 1.04
No Computer Needed
Steps:
1. Download Kit
2. Extract To ("/sdcard/clockworkmod/backup")
3. Boot Into Recovery
4. Restore Backup
5. Reboot Into ROM
6. Turn Off Airplane Mode
7. Get MSL using MSL Reader
8. Write Down MSL code
9. Go to dialer & enter ##775#
10. Click Update PRL
11. Select PRL then press "OK"
12. Click Menu key to open menu
14. Click Commit
15. Then reboot into a ROM with data to test data speeds.
Download: Dev-Host - - The Ultimate Free File Hosting / File Sharing Service (Link By Ramjet)
Credit: Ramjet73
Requirements:
S-Off
4Ext(or CWM)
ENG HBoot 1.04
No Computer Needed
Steps:
1. Download Kit
4. Restore Backup
5. Reboot Into ROM
14. Click Commit
