hugerichman
This thread was completed on my phone as I am not home at the time, so if there are any errors please notify me of them!
Since the update to 6.0 I was waiting for someome to confirm that Xposed still works for MM. After a while, I knew there weren't going to be any soon so why not take the risk for the sceptical people out there
Before we start, use at you own RISK.
I am not responsible for any damage you have done to your phone by attempting this!
You will need the following files:
The Xposed Framework: http://dl-xda.xposed.info/framework/sdk23/arm/
Then you will need the Xposed Installer apk: http://forum.xda-developers.com/attachment.php?attachmentid=3383776&d=1435601440
YOU WILL NEED TWRP TO BE ABLE TO INSTALL THE XPOSED FRAMEWORK!
If you need a tutorial on how to install twrp referr to this link: http://androidforums.com/threads/guide-how-to-root-t-mobile-6-0-update.1008880/
Instructions on installing Xposed are pretty simple!
After you have downloaded the apk install the apk but DO NOT OPEN IT!
This is now when TWRP will be used.
After you have downloaded the framework for Xposed place the file where you will remember it, or leave it in your downloads folder.
Boot into TWRP by using Power+Volume Down (Or make it more easier and use Flashify) then click on "Install"
Select the zip & Install. Wait for the Installation to complete. Now, Wipe Dalvik & System cache. Reboot your device.
After you reboot you can now open Xposed Installer and start installing some mods
If there are any questions or problems, I am always happy to help
Source:
https://devs-lab.com/how-to-install...#Download_Xposed_Frameworkfor_Android_M_60601
Source:
