Root [GUIDE & TOOL] - De-Bloat Tool For 2.3.6
Killah1994
Android Expert
This is a simple to use De-Bloat Tool for the Samsung Admire 2.3.6 , this tool allows users to remove all bloatware (except Metro App Store) , without accidentally deleting apps which could soft-brick your admire.
This script removes the following bloatware:
  • Metro Navigator
  • Metro 411
  • Social+
  • Metro PCS Easy Wifi
  • My Metro
  • Rhapsody
  • Google Books
  • PinYin Keyboard
  • Think Free
  • Metro Studio
  • Google Korean Keyboard
  • Visual Voicemail
Requirements
  • CWM Recovery w/ ADB
  • Windows XP or Higher
  • USB Drivers
  • Root Access (Most important)
  • Phone connected to PC with USB Debugging enabled
Instructions
  • Download Debloat Tool By Killah1994
  • Extract Onto Desktop (or somewhere you can access it)
  • Connect Device To PC & Have "DEBUGGING ENABLED"
  • Run Debloat.bat
  • Dont be scared if it reboots into CWM Recovery (Its part of the process)
  • While in CWM Recovery it is recommended not to touch the device during this process!
  • Then follow on screen instructions from Debloat Tool
Download -
Credits To -
eaglerazor123 - for his guide on how to make this tool
