Root GummyJar Question
lennydude
Android Expert
I am running GummyJar 2.5 rom on my X and really like most of it. The camera app i do not like.
I downloaded the "DX_Camera.zip" file and want to make sure how i should load it?
Do i copy the file to my SD card and reboot into bootstrap and run the zip file there?
Thanks much...............also, the Gallery IMO is not good. Is there a way to fix that?
Thanks........... Lenny
Yes, download to your SD card, reboot into bootstrapper, and install zip
If you are running GummyJAR 2.5 then you should have two galleries. One is the old 2D gallery and the other one is the newer 3D Gallery. Try them both and see which one you like better (pretty much those are your only choices). Then delete or rename the one that you want (either Gallery.apk or Gallery3D.apk).
Hope this helps... :D
Ha, thanks for that info. I was wondering why I had 2 galleries.
I didn't like either gallery so I flashed the old moto one. If you want it I threw it up on mediafire here
You would flash it just like anything else.
