Root GUYS help mee plzzzzzz!!!!!
kall1as
android version 2.2.2
baseband vers 32.49.00.32u_5.11.05.27
kernel vers 2.6.32.15-gf5a401c htc-kernel@and18-2 #1
Build Number: 2.29.405.14 CL345208 Realease-keys
softw number 2.29.405.14
web kit 3.1
how to root this one guys please help!!! i used unrevoked but it says that my firmware is too new, i dont know to do!!!!some advice????
web kit 3.1
There has been a few threads on this. from memory, it is not the phone, but the drivers and/or apps installed on either the phone or PC. myphoneexplorer i think is a problem app
or you could use revolutionary..
Hi Gurus,
I have the exact same config as Kall1as and the following Hboot info
BRAVO PVT4 SHIP S-ON
HBOOT 0.93.0001
MICROP-051D
Touch Panel SYNT0101
RADIO-5.11.05.27
What software do you recommend?
The root guide to 2.2.2 recoomends unrevoked but for ARA Build 2.XX.415 my desire isn't 2.XX.415 its 2.29.405 not sure if I should use the same or not...
@Kall1as did you eventually root yours...
Okay so did you know you have to S-OFF your device before you can root it?
Heres how you can S-OFF
if you have us-cellular or verizon, Select CDMA
If anything else, just select the regular htc desire option
-Liam-
