H2000 phone help
Welcome to the Android Forums!
Software developers are able to indicate in the market which devices do and do not support their app. Your Chinese manufactured device very likely just randomly chose a known Android device to identify itself as. It sounds like that device is not listed as supported for the apps you seek.
My phone is a H2000 iPhone 4 Clone with Android 2.2 Froyo (Im no noob, I know it's running legit Android Froyo). Here is the problem: I have went to Settings and then Manage Applications. I scrolled down to the Settings application and clicked it.
I selected the buttons Clear Data and Clear Cache. I was then sent to the android homescreen. Since then, whenever someone tries to call my phone, My phone will vibrate for a second, not show anything on my screen, then display on the other callers phone "User Busy". However I can still call to other people, that works atleast.
Do any of you know a solution? The phone is definetly getting the call because it vibrates when it gets the call, it just doesnt show anything on the phones screen, thus I cannot accept the call and then the other caller gets "User Busy" on their phone. Any advice? Please? Im really stumped here
. Thank you in advanced!
Edit: The phone was working FINE before I did this to the Settings application.
Thanks a lot
Thanks a lot
Sounds like one of your only options is to do a reset. (Have you tried power cycling the phone and pulling battery out while off?) If so then a hard reset is probably the only way to go.
Let us know....
Let us know....
I tried all possible combinations, and remove the battery and all. The only remaining "Factory reset", but he can not do, because they will lose cell phone IMEI, later it is difficult to go back to.
Sorry for my Google translation
Thanks a lot.
Thanks a lot
Have you solved your problem? This guy claims to have the solution: Soluci
