rendeiro2005
This is ONLY for testing proposes and i WON`T be responsible if you didn`t backup first!!!
Here`s 3 zip files to install through xRecovery. This should work on any rom/mod (i`ve tested on my [Cyanogen6.1.3]gingerbread[v01] and on Jerpelea Gingerbread v10a and v11) so if you want to try, do
If you test this use it AT LEAST for 2/3 days to check if it really works. Thks
WTF is this?!
Well...
Basically this will "mess" with your build.prop file, vm, lib files, network, memory, OpenGL, etc, etc, etc.
Working on ROM/MOD
Cyanogen CM7.0 RC2 v010 Gingerbread 2.3.3
[ROM] CM 6.1.3 V4.5.7 with Camcorder [19-03-11] [Tweaked+Theme+Extras]
Stock SE rom - Should work on every one of them
Procedures
1. Backup your current ROM/MOD
2. Copy the desired zip file to your SDCARD
3. Reboot and enter on xRecovery
4. Go to advanced optons and Fix permissions
4. Search your copied zip file and install it
5. Reboot.
Download Files
DON`T install both!!! If you do that only the last one installed will be active.
Choose based on your preference.
PRF rendeiro2005 Tweak's v3.0 - Performance proposes
BTY rendeiro2005 Tweak's v3.0 - Battery proposes
If you want to remove the above tweaks this patch should do it.
[Remove] rendeiro2005 Tweak's v1.0
Future Releases
On next release i`ll try to:
- Change current .zip files so they will be able to automatically delete some build.prop infos to avoid incompatibilities;
- Create two versions for each. X10(a) and (i) - for network settings
Regards
Ricardo Rendeiro
