upgrumpy
Is there an app out there or can Tasker make a widget on your home screen that will take you do a certain point into another app (like a macro would) I use Handcent and I go the sounds settings a lot and I would like to create a widget or task or find an app that would take me to
Handsent-menu-settings-notification settings-notification settings-notification sound
any ideas?
Thanks
any ideas?
Thanks
