Handcent /Messages
slatyford
Anyone any answers, handset has stop letting me pick recipients or sending txt messages but it will let me reply to txt.
have tried reinstalling but still only works once. Tried rebooting but still nothing. I like this app but its starting to jack me off now and now either need a fix or a suitable replacement
this happened months ago to a few of us, basically wait for an update, you can contact the developer and try rush things through, when it happened to me it was a bug and nothing would fix it apart from an update, use stock sms till then
Did you select "only show contacts with mobile numbers" by chance?
No haven't changed the settings since I first installed it months ago just updated when an update was available then it just stopped working properly tried rebooting and reinstaling and the same problem every time so using chomp for now
Sorted, I had unchecked social network box and as everyone I usually text is on my social network list it wouldn't let me txt them
