Handcent MMS Problem
wrice4
Hey guys, this is my first post and I have searched accordingly and have not found the solution I am looking for.
I can send picture MMS on my Fascinate but everytime I want to attach a file and choose camera (take the picture right now) it never sends the picture I take, it sends a picture I took about 3 months ago, that is not even on my phone.
I can choose attach and then picture to pick one from my phone and it works great, but when I try to attach then choose camera, it just sends one that I sent 3 months ago and I can not change it. Any help? Am I making myself clear?
You are making yourself clear...kind of. You go into compose and attach a picture using the camera (taking the picture right there and then). But instead of attaching that picture you just took it attaches a different one from 3 months ago. Correct? What I don't get is when you said "That is not even on my phone". But anyway, this seems weird...try all the usual suspects: Search the handcent settings, the phone settings, the stock messages app settings etc. If no luck I can only suggest a reinstall.
Correct? What I don't get is when you said "That is not even on my phone". QUOTE]
The picture it sends instead of the one I take is not on my phone. It is not saved on my phone and is no where to be found in my gallery or anything.
I have looked through all the settings and can not find anything that may be of any help. I will look in the handcent files. Guess im going to have to re-install. Thank you for your help.
The picture that you took 3 months ago, did you try to send that picture? Or was it just a picture you took and then deleted?
There we go. Something happened when it failed to send and now it's resending whenever you want to send a new picture. Still don't know how to fix it though lol.
Yes. I have my phone hooked up to my laptop looking at all of my files. I can not seem to figure out where this file is at so I can delete it! There has to be a way to find the file that has been pending all of this time ?
You can download an app like astro to search your phone for files but I have no clue where it would be. Have you tried the reinstall yet? Could be the easiest way to solve it.
