Handcent select mobile number
pradhr
Hi,
In Handcent application, when I compose the SMS text and then press on "+" sign to select the contacts. I found some numbers appear twice.
(1) When I select one of that number which appears twice, and then press return button, actually that number does not get selected. Then I press "+" sign again and then select another number and press return button. Now it selects that number.
I am not sure which number get selected and which is not!! And why?
(2) Why the numbers appear twice? Is it showing both my Google contacts and contacts in phone? But I don't know, from where to change this settings?
(3) Same way, my groups are also appear twice?
Thanks.
It will pull them from wherever you have contacts. Phone, SIM, Google, Twitter, etc...
Personally I don't synch any contacts with my phone and ONLY have phone contacts.
