Sometimes you can go into the phone's "people" app and tell it to only show the "Phone" contacts or the "Google" contacts.. either way, this might work, can't confirm this.
go to http://www.google.com/contacts and set up your contacts there, then delete all your contacts, then tell your phone to sync up with your google account. Then it should sync only google contacts into your phone...
Update on this... My contacts under "other" on my gmail had all the contacts messed up, they were doubled, and sometimes tripled in that list. I had it search for duplicates and merge, and it is all fixed now.
