Help Handcent vibrating pattern issues
daspaz411
I found this to be a problem with both handcent and chompsms, but the vibrating patterns do not work. I set it to multiple long and had stock notifications off and when I got a text the phone actually did not vibrate at all. Is it just me or is this for everyone?
I also find the custom patterns doesn't work, but the others seem to.
Sent from my ADR6300 using Tapatalk
First, I was having issues where my phone was not vibrating with Handcent. I downloaded Sound Manager, hit menu, and made sure that the vibration occured "whenever possible" on notifications, and that solved the problem.
Now, when making a customized pattern, you must enter the pattern in this format:
0,200,100,200,100,200
NOT this format:
0, 200, 100, 200, 100, 200
Spaces will not be recognized and will null your entries...
