Handsfree Problem
Naff47
Hi there! :D
Hope you guys can help because I have a problem which is really bugging me.
I've just had my phone repaired on my insurance. I own a Xperia X10 Pro and they have updated the firmware on the device upon fixing it.
My problem is that it now does not see my handsfree device. I own a Supertooth bluetooth device which just isn't being picked up ever since the update which is very strange.
Is this a known issue and can it be fixed?
Many thanks.
Hi there! :D
Many thanks.
You will have to go through pairing the devices all over again.
Should work. Try with any bluetooth device. Even go to a store and try a bluetooth device out if you can. Make sure that bluetooth on the phone does in fact work.
If you are using any sort of security program that might prevent bluetooth from working properly.
