Hard reeboot
  • Start date Start date
Hello. To create a hard reboot you will want to remove the battery for just a minute and then replace and power up your phone. If you are looking to factory reset your phone (taking it back to factory fresh) you will want to ask again stating that is what you are trying to achieve. I hope this helps.
