im aware of that.. but things such as texts aren't on my sd card..
There is no way to natively do it from the phone. If you want to save Texts/ Call logs/ ect then i suggest getting the 5 dollar app "MyBackUp Plus".
Lifetime license and works like a charm. 2 options come with it after its installed.
Saving your apps (Save on SD card, save online)
Saving your Data (Save on SD card, Save online)
If you choose data then it gives you more options on what to save. I save it all but you can pick from Contacts, Call Log, Book marks, SMS, MMS, System settings, Dictionary...ect ect.
That will save everything you need. And it comes in handy if there is every a time in the future that you need to do another reset or if you root and flash a ROM you can restore all that stuff.
Just download from market then do a restore. Whats nice about it is a scheduler it has. I have it save every Sunday at 4am. This way im not using it and it has a weekly back up and i dont need to remember doing it.
You can toggle the times and days you want it to save too and what all you want saved.
Worth it for 5 bucks IMO.
