Hard to zoom camera
sukayser
When using the camera app of my Droid, I often want to use the zoom. In the recent version of the camera, this has become extremely difficult. First you tap the "1x" icon on the side of the screen, which brings up a slider. Then you are supposed to slide the bar to the desired zoom level. The problem is that the bar won't slide most of the time. I've tried touching it lightly, firmly, holding it
