Hello,
So my EVO decided it didn't want to display anything except blue and pink fuzz. (see picture) It wasn't dropped at the time of malfunction, or even recently, but it has taken a good number of bumps and bruises since I've owned it.
If I give a little squeeze along the left bottom side of the screen I can occasionally get the display to come back, but it is only briefly and nothing really works. The weird thing is that the touchscreen still works. If someone calls me I can answer it just by swiping by memory the way I always would. I can even hold the power+home key and take a snapshot of the screen, but the image that is saved isn't the fuzz it is what should be there. All in all, the phone is working. Just the weird screen issue.
I cracked it open and inspected all the connections and ribbons, and everything seems fine. I obviously didn't remove the LED, because that would have trashed it and the glass, but I got to that point of inspection.
What do you folks think? Is this a ribbon issue, like a bad connection, or is the display going out?
Thanks, any information is appreciated.
Mac
Mac
