Well, the OTA Marshmellow update went well and everything was actually working fine for a few days until all of a sudden, the screen showed the words "Google" on a black screen and from that point on it has basically been bricked. The word stays there forever. I hold the power button down and eventually it'll turn off, but when I try to turn it on again, I get the same result.
After trying everything, I decided to do a hard reset and do a wipe data/factory reset in Android Recovery, and even that is failing. I get error messages and am getting exactly the same behavior as this person described in this thread: http://www.androidauthority.com/com...-update-has-rendered-my-tablet-useless.18555/
I hope it's not against the rules to post such a link, but I wasn't sure if I could describe it any better. It seems that this may be an issue with others as well. My tablet is long past warranty so not really sure what options I have (other than perhaps reflashing a ROM?). So, just curious if anyone else has run into this issue.
