Has anybody used launcher pro with galaxy apollo?
j0nb0y
What are the benefits and how does it work? Does it run on top of touch wiz or does it replace it? Does your phone run noticably slower with Launcher Pro or is there no effect?
Can it be uninstalled just like a normal app, reverting back to default touch wiz?
I am using it for some time right now...
Launcher Pro is far more customizable. You can change your icons, and have more options for the launcher itself like the transitions...
It does replace Touch wiz. You can stil choose between both launcher everytime you push the home button, or you can set launcher pro as default. Launcher pro is actually faster than the original launcher so it doens't slow your phone down, it makes it even faster...
And yes, yo can uninstal this like any other apps... just give it a try, it won't harm you phone in any way.
