Accessories Has anyone found a horizontal leather case that'll fit an EVO with the Seidio Innocase?
tracerit
Sprint's official EVO leather case doesn't fit and it looks very nice too :/ Seidio has their own horizontal leather case but that thing is bulbous and I don't believe it was designed specifically for the EVO, it fits a wide range of phones. I've had that case before.
Not a fan of the holster from Seidio because i"m concerned about it falling out and being exposed like that. I also work in a hospital and it'd be nice to have a leather case to protect it from any stray fluids -_
that looks pretty good! i'm kind of worried about the width though, the evo is ~2.6" and that one says it's good for 2.3"... :/
do you have the seidio innocase as well?
I got a case @ Target it's a universal one, any leather case is gonna be huge but it fits my phone and the body glove case no problem!
Can you post a pic of the Target case? I looked at Target and didn't see any that would fit with the Body Glove case.
I think the measurements on the case from Amazon does not take into account the flap that goes over the top of the phone. The case should be ok. I should get it tomorrow, I'll report back.
Seidios premium leather holster is huge. I had one for my touch pro 1 and it was too bulbous. Not sure if those cases are fited of not.
Best Buy sells a horizontal leather case by Rockfish. I have that case and the Seidio case and the Seidio fits inside of the Rockfish very easily.
was this the $19.99 one? i went to best buy and the seidio case didn't fit in there very easily. it took a while to jam it :/ can you take a pic of it?
Yes, it's the 19.99 one. Here are some pics.
interesting.... does it go in and out easily? when i tried it i didn't have the phone yet so i played around with the seidio case only. i'm going to try it out later tonight if i can.
It fit snug the first two days and then loosened up a lot. So much so that if I ever decided to take the Seidio case off it might be too loose of a fit.
thanks, i went to best buy and picked up the rocketfish. it fits PERFECTLY this time. i guess the first time i tried it at the other Best Buy it wasn't loose enough.
That's good to hear about the rocket fish case. I saw it at the store today and it seemed pretty tight when I stuffed my Seidio'd Evo into it. Might just pick it up and see how much looser it gets.
