thecarlsoncrew
I have an unrooted (Verizon) Samsung Galaxy S5. I'm not a fan of stock Lollipop, so I'm looking for the best way to get into CyanogenMod. I tried their easy online installer, but it said my device wasn't supported. There was a button to proceed anyway, but I thought it best to do a little research first.
Apparently, there are only nightly builds available for the GS5, not stable/RC/milestone. Is that what the installer will put on my device if I continue past the unsupported warning? Has anyone used the installer in order to install CM on their GS5, and have there been any problems?
Outside of this, it seems the best method is rather laborious - downgrade to KitKat 4.4.2, then root, then install manually. Any other thoughts or suggestions?
