Have Go SMS PRO How do I create Groups?
Depends on where you have your contacts saved.
If on phone, go to your contacts app>groups tab. The create group and add to group options are there.
If on Gmail, Google for Google Contacts, then login and manage them there.
Ok Well I had it before where I named my group and could send out a mass text to everyone in that group now it seems I have to check mark each name
I can still do that on my Go SMS Pro. Open Go SMS, click on the + contact icon beside the space where you put in the names of the persons you want to text, then select the groups tab. Beside each group name is a box which you can press to check mark the group. This will select every member of the group fot texting.
FYI I'm running latest Go SMS update.
