Restart Windows after the installation even if you aren't prompted. Enable USB Debugging on the phone and then plug it in to let your computer detect it.
Make sure you are using the USB cable that came with the Bionic. Not all USB cables are created equal, which is why the recommended one is suggested since it is a known proper type. ... Plug into the back of the PC if it's a desktop, laptops you can use any of them. There are systems like Dell ( and others ) with some pretty funky aka non-standard USB ports... so if the first one you try doesn't work right, plug into another one.
