Help Having issues with language and input settings
enath79
Hi everyone I am a long time reapossible fix would be appreciated.thank your first time poster. I have come across an issue I cannot not solve in matter what. I have kyocera rise running 4.0 ics. My keyboard recently stopped popping up. I go into the language and input settings and I see my keyboard listed. When I touch to select it it will s grayed out and nothing happens. Also in my text messaging I do not get an input notification in my notification bar. I also have a rooted phone and my superuser prompt is not coming up. Any apps I use that have an in app pop-up window are not coming up. Okay here are some things I have done recently. Factory reset and re rooted. I was in the app removal section of the Titanium Backup app and I am not sure if I deleted a essential system app by accident because I accidentally clicked the green check icon before hitting de-select all and closed the app for those of you whho are familiar with the apps interface. And last of all I recently swapped sd cards. As I said there is no mention of this error online anywhere and u see people get help here all the time. Any points in the right direction on a po
