Help Having issues with my USB connection
intrdrgn
Android Expert
i recently loaded CM7 which looks awsome, trying to conect my phone to my CPU & it is not reading it. i tried my Device Manager to resolve the connection but had no luck. i have windows Vista, but i read somewhere here that CM7 doesnt install our drivers. what can i do to fix this.
i tried that still same issue. i flashed it back to 2.1 still no go. i checked it through my computer & its telling me i dont have the Android adaptor USB drive. i have an SD card reader, can i use that for the time being?
2 things...if the USB drivers in that link don't work you've done something wrong. I can (and others) confirm 100% they work. Make sure you unzip the file and run the .exe file with the phone plugged in.
2nd, yes you can transfer files via a card reader. Great little tool to have in case something goes wrong. Good luck.
I wasn't able to connect to USB even with the d/l drivers. I disabled Juice Defender and that solved the problem.
so how can i fix this? i am trying to restore to original and reflash cm7 the right way lol and not doing a quickie like i did.
think thats how i messed mine up, did too fast just to see what all the fuss is about cm7 and now im f***ed lol
missed a step or something i guess.
