I have just started a T-Mobile contract in the UK on the Full Monty plan that gives unlimited data and includes tethering.
The handset used is unbranded and unlocked but I couldnt tether with it for some reason, either via wifi hotspot or USB Tether. The internet on the handset worked fine.
I couldnt call 150 customer service as that dept shut at 10pm so had a play with the apn's.
The three APN's set up as default are all locked and uneditable so my plan was to edit the broadband one in someway.
So, I copied all the settings, set up the APN's as another network, deleted them and added the three default APN's manually.
Once I did this, tethering started to work, with no actual change to any of the settings.
Just a heads up if anyone else comes across this and a fix that worked for me.
Steve
Steve
