having problem with task killer and whatsapp..
wahyudi
hi guys, need some help here...
i just bought the optimus one, and i installed whatsapp on it...
but when i try to run it, the 'alert' sign poped out...
it says 'you have 3rd party task killer installed. task killer can cause problems with whatsapp messenger and the unsupported by our customer service team'
what is that mean ? and what should i do ?
:confused:
ya me too... I'm not having any problem with whatsapp and a task killer.
try using advanced task killer... it works fine. you can also add whatsapp onto the ignore list so that it doesn't kill it.
I would recommend uninstalling the task killer, task killers are bad for android:
I develop Android apps so I though I'd explain why a task killer isn't needed on an Android system.
Activities
Android apps use activites to preform tasks. For example, if you use a file manager to send a picture via email, the file manager calls the send activity within an email app, passes the file name to it and the email app sends the picture.. not the file manager. This will result in seeing the email app as "running" even though the user didn't actually launch that email app.
Smaller apps
Using activites helps developers design smaller apps. A file manager app that contains every bit of code needed to do everything a file manager does would likely be so large that no one would want to install it. Developers know that an android phone more than likely has an email app so there is no need for the developer to include email code in his/her file manager to send a picture when he/she can call an activity in an existing email app to do the job. This results in a smaller file manager app since there is no need to include email code or any other code for an activity that can be done via an app that is already present on the phone. This also alleviates redundant code. When you install an app outside of the android market, also known as sideloading, the file manager app calls the package installer (already present in Android) to install the requested app.
Running apps vs. cached apps
The "Manage Applications" list included in many android devices lists running apps as well as cached apps. Cached apps don't use any CPU or battery, they're cached so they will load faster the next time you need them. Killing cached apps results in those apps requiring more time to load the next time they are launched.
System management
By default, every android application runs in its own Linux process. Android starts the process when any of the application
Wingy
mine is just 'task killer' red in colour...
ardchoille
what is .apk. ?
and how to delete task killer ? i did uninstall it, but i could not delete the file from my system..
A .apk file is a compressed archive of files that Google uses as the file type for android packages. If you uninstall a .apk file it should be completely removed from your android device.
ya I agree with ardchoille. but the apk file may be from when you downloaded that app from the internet. its just the installation file. you could actually just delete it from browsing it in Thinkfree Office.
Try looking for "Advance Task Killer" from the market. Its quite cool, because it even have an option for auto kill.
