PGB1213
Hello All!
I have a ZTE Maven running Android 5.1 on AT&T. I am having three problems that are new in the last few days. Sorry for being pesky; I tried to find the answers on my own, but came up empty, so I'd like to ask here.
I have 3 home screen panes. One has 2 folders that have some app shortcuts. If I try to place a new shortcut on any home screen, it automatically gets added to one of the existing folders o matter where I land it.
Here is how I do the shortcuts:
I click the Apps icon at the bottom of Home Screen One and hold on an icon. I drag the icon the the screen I wish the app short cut to be on. I wait, but nothing lights up or flashes so I let go. The icon lands in one of the two folders- even if they are on a different home screen pane.
I also can't drag the shortcuts out of the folders. The folder pop-up covers the whole screen, so the only choice is to delete.
Problem Two is that I can no longer make folders on the home screen. I used to simply place a shortcut on top of another and a folder appeared. I then was able to name it. This no longer works.
Problem Three is that app shortcuts are disappearing randomly. All of a sudden, one or more will be gone. Sometimes restarting the phone brings them back, but most often it does not.
Do you all know what in the world is going on & how I can get stuff back to normal?
Thanks Very Much for helping out!
Paul
Paul
