Help Having trouble connecting to home WiFi
Pazma
I have a Huawei Ascend G300, it's brand new and I tried to connect to my home WiFi setup. My laptop uses the connection without problem. I have entered the WiFi key multiple times and even copied it from a text file to make sure there's no mistakes but it just won't connect. It sees the connection and shows that it has an excellent signal but won't let me sign in. Any ideas please?
Phone:
Huawei Ascend G300
Model Number: U8815
Operator:
Vodafone
Android Version: 2.3.6
Baseband Version: 109808
Build Number: U8815V100R001C02B886
Router Information:
Router Name:
Netopia
Model:
2247-02
Serial Number:
16727632
MAC Address:
00:1e:5a:ff:3e:50
Software Version:
7.7.0r6
Router Settings:
Default Channel: 7
AutoChannel Setting: At Startup
Enable Closed System Mode: Not ticked
Block Wireless Bridging: Not ticked
Privacy: WPA-PSK
WPA Version Allowed: WPA Version 1 &2
WiFi Multimedia: Disabled
Limit Wireless Access by MAC Address: Disabled
If it was me... then i'd do a restart on the router and phone (make sure fastboot is off) to see if that makes a difference.
Then i'd make sure mac authentication wasn't turned on in the router.
If that didn't work i'd turn off all the security on the router, get the phone connected, and then turn up the security bit by bit until you find out what stops it connecting.
done exactly as you said. turned off the security on the virgin super hub and phone connected to wi-fi no problems. as soon as i turned on the lowest level of security, the connection was disabled. so choice is a secured hub or a wi-fied phone.
Not sure what to suggest, but I'm using the g300 on a virgin superhub with wpa2 turned on and it works just fine...
cracked it. turn hub and computer off for a minute, turn on, go to web page for hub ( http:// 192.168.0.1 ) change the passkey. turn off phone and any other connected stuff. turn on and connect to wifi. it will ask for password. enter new one and bobs your uncle.
