I was researching this issue as well. It's the same issue with MAX (cinemax) GO. Just blank screen no video but audio is ok. I think it might* be an issue with gingerbread. Not sure. Netflix is the only streaming video that works fine. Since it supports flash, you can go to hbogo.com and login from there (use PC mode) and it should be fine.
