I dont get it im confused
sounds louder...
sounds clearer...
sounds better...
try it out
is it on all the time?
in the music app,
select the song you want
hit menu
hit 'sound enhancer'
select 'high defenition'
hit ok
should have hd audio from now on
what if you use poweramp what happens? does it work on youtube?
Is there anyway you could consider making a flashable zip for the hd audio Mobs?
power amp has a setting that will enable it to be used in power amp, otherwise it will use its own equalizer. as for youtube, I'm not sure.
