HD Playback
SS2006
Can the phone play back 720p movies, like the Omnia HD did
Just ordered it but was kind of curious about this
Thanks
Is this because it is lacking hardware or software capabilities?
I'm sure the Nexus processor is faster then that of the Omnia
Can it play any form of high quality videos, not neccesiarly full 720p, what formats...
Thanks btw :)
Snapdragon is a mighty little beast, but I'm afraid for HD playback you'll have to wait for a phone on nVidia Tegra chip.
Nothing special, surprisingly. An ARM Cortex-A8 600 MHz CPU.
The point is, if Omnia is capable of recording 720p - encoding video - apparently, the chip responsible for hardware on-the-flight encode is also capable of video decoding. Just my theory.
Much as I want HD playback. It would only be to keep one copy of HD clips. Not have to make 2 versions.
Thered be no point in watching HD on Nexus screen which is dvd resolution.
Until we see 1280x720 res screens it wont matter much.
Well, some Nokia devices came with tv-out. If a phone had an HDMI out, you could use it instead of a standalone HD media player.
Well... The Nexus One = HTC Bravo... Just with less stuff turned on...
A closer look at the updated specs of the Android-powered HTC Bravo – Android and Me
The HTC Bravo will have Divx playback + 720p vid recording... And if you can record a 720p vid... You "might" be able to playback your recorded 720p vid's @ 720p.. Wonder if this will be done without any down sampling...
Now the Nexus one won't be able to do any of the extra stuff the HTC Bravo can do without rooting & some Cyanogen magic... But anything the HTC Bravo can do should be able to be ported over to the Nexus without much hassle since they are identical although different looking twins...
