HDC A9100 GPS Problem
IamJeff
After two firmware updates and trying every setting I can think of, I still cannot get the GPS on this phone to get a fix on any GPS satellites. I even tried rooting and then using a program called FastFix (or FixFast, I can't remember) but that still did not work. Has anyone had any luck with any of the firmware updates? Any suggestions?
Thanks for the reply. I already installed GPS Test and used it to confirm the problem. Sometimes, the device will see multiple satellites, but just still not be able to get a fix. Maybe they forgot to connect the GPS antenna in this one. By the way, the HDC A9100 is a look-alike of the Samsung Galaxy s2. Nice phone in all respects, except for the GPS issue.
Hello,
how did you make the root?I have made the updatew and i still have the same issue with the GPS.Any new solution?
I ran their updates that were supposed to fix the GPS problem, without succcess. I then rooted the phone but that did not help either. I ran another utility called FastFix. This is supposed to modify a GPS config file on the phone to help get a faster fix on GPS satellites. This did not help either. I contacted FastCardTech.com asking for a refund because they knew the phone had GPS problems. They refused. I then contacted my credit card company and initiated a charge back. I now have my refund and I sent the phone back, they even paid the postage. I am now the proud owner of the real Samsung Galaxy s2. Great phone, fast, and the GPS is perfect! Well worth the additional money.
I bought the phone pas September.How can i make a refund and charge back after these months?Paypal can't do this after 45 days.
Did you use a credit card for payment? If so, you can contact your credit card company. Explain to them the efforts you made to resolve the problems with your phone. I had paid using PayPal, but had my credit card attached to my PayPal account. To be fair, did you work with FastCardTech first to try to resolve your GPS problems? Did you apply the firmware updates? They also told me that the phone would be compatible with the AT&T 3G network, but it would only use the 2G network. Good luck!
Hi IamJeff,
Thanks for posting this. I intend to buy one (HDC A9100). May I ask a few questions:
1. how much available storage left inside the phone, for additional apps?
2. RAM is 512MB?
3. Do you know it support 3G at 900Mhz?
Thanks in advance.
