Help hdmi connection problem hisense pro 7
A
Android Question
Guest
How do I enable HDMI output on tablet it used to work fine on TV I borrowed another his sense tablet that one works have I turned something off
Hi
Get the app running on the tablet and then connect it to the TV. ie try unplugging and replugging to the TV when the app is running on the tablet.
Roger
I have tried but TV just said check connect ions but I know the cable is fine I need to know how to enable the HDMI port on tablet as it won't pick it up anymore as I say I borrowed someone's same tablet as soon as I plugged that in it came on as mine used to thank you.
