Accessories hdmi cradle issues
92slammer
anyone having issues with the dock....the last few nights after i set my phone on the dock to charge(its also my alarm clock) i wake up to find the battery almost dead....the other night my phone was completely dead.....while sitting in the cradle. the phone charges fine if i use a regular wall charger or usb. oh and ive had the dock since the 15th....this just started the last few days.
The first dock I received started to act up. I had the same symptoms as you did after a few days of using mine. The dock screen would say charging but under about phone, under the battery status it would say discharging. I just brought it into a Verizon store and swapped it out.
That happened to me once. You have to make sure you push your phone all the way down until you see that it is charging.
However, if it is all the way down, and it still isn't charging...something must be wrong. Check your cable maybe?
